769Views6Replies
Author Options:
Powering 6-8 Servos simultaneously?? Answered
I am currently working on a project that involves 6-8 servos, that all need to be powered at the same time. What would i use for this? The power supply on the "robot" of sorts will be a 11.1v Li-Po battery (Will update with mAh/any other info needed on the battery in a few days, i do not currently have it on me). Is there any BEC/UBEC capable of doing such a task? Could i use a combination of more than one (Three UBECS off of the same battery, all in parallel)? The servos that i am using are TowerPro MG995 Digi Speed servos.
On a slightly different topic, are there any BECS/UBECS that can monitor the battery's voltage, and shut off when it drops below a certain voltage?
Links would be great
Thanks!
Wired_Mist
Wired_Mist
Best Answer 6 years ago
A BEC (Battery Elimination Circuit) is just a fancy RC name for a Voltage Regulator. (And a reason to charge more, for something you can easily build you're self) I'd use a simple LM-7805 (5V regulator @ 1A) 8 servo's at 100 ma each will leave you with %20 Over kill, should work fine.
Alternatively you could use a dc-dc converter,
http://www.adafruit.com/products/1385
Either way just regulate the output to the voltage you like to run them at. The data sheet says you can run those servo's @ (3V - 7.2V) So 5V should do fine.
You could use a resistor divider and just about any standard transistor to make your low voltage shut off.
Btw.. Be sure to use at least a 2000-mah battery; maybe even have a second one on the charger that you could swap out?
Good Luck !
iceng
iceng
Answer 6 years ago
+1
While a down converter saves battery time, did you notice Lady Ada is out of stock ?
Wired_Mist
Wired_Mist
Answer 6 years ago
why no I didn't >.> my bad
Still gives him something to start looking for
Here is a peice thats acctually in stock, Thank Iceng !
** EDIT**
http://www.ebay.com/itm/DC-DC-Step-Down-Converter-Buck-12V-to-5V-3A-15W-output-voltage-regulator-/261335563607?pt=LH_DefaultDomain_0&hash=item3cd8d03d57
rickharris
rickharris
6 years ago
They need to be supplied with 5 volts (some with 6 volts) The total current will be the peak current of each servo added together (see spec sheet).
You can supply from a battery but will need a regulator to reduce the voltage to 5 volts.
RocketPenguin
RocketPenguin
Answer 6 years ago
6v input, working current is ~100mA. 6 to 7 servos, so i would need a 6v 1 amp UBEC/BEC, right?
RocketPenguin
RocketPenguin
Answer 6 years ago
I already have soemthing that controls the servos, i need something to power them.
