134Views8Replies
Author Options:
Powering oven resistor Answered
Hey :)
Does anyone know how to power an oven resistor ? Is it really a simple resistor (I'm not sure as it is directly exposed in oven, it seems too dangerous for the user if it is simply a metal stick) ? If I plug it to 220V sine 50Hz will it heat ?
QuentinP16
QuentinP16
2 years ago
Ah ok, perfect, I didn't know for the coating but it seemed to be a bit dangerous without ^^ It will be easy to add to my project ! Thanks for your answer :)
Toga_Dan
Toga_Dan
Answer 2 years ago
whatcha makin?
QuentinP16
QuentinP16
Answer 2 years ago
A drying box for meat :p The resistor will be used to maintain the temp to a certain level.
Toga_Dan
Toga_Dan
2 years ago
you could probably power it at 110v if u dont hav 220 available. u may not get the top o the temp range tho.
Toga_Dan
Toga_Dan
Best Answer 2 years ago
not quite a "metal stick" more like a coil of nickel chromium wire coated in ceramic . But, yes, it does take full voltage in an "on / off" circuit controlled by a thermostat
