74Views3Replies
Author Options:
Premiere pro wont load, uninstalled and re-installed, still won't load ?premiere pro wont load? Answered
Loading premiere pro, won't load. I uninstalled, and re-installed. Still same results. Says can't move file.
Tags:sean
Quadrifoglio
Quadrifoglio
4 years ago
Try a Google search like premiere pro can't move file. You will get things like First, if you've got the track view set to show track volume or track keyframes, you can't move the clip. Hide the keyframes before you attempt to move the clip. Find what works for you.
ShawnS106
ShawnS106
Answer 4 years ago
It is a really simple solution. If you know anyone error code 42 I think but the error code is cannot move file. the solution is to turn off antivirus it blocks the file from moving for some reason. you can shut antivirus off for 1 hour load comma and turn back on. then you run your antivirus Suite just to make sure. end of story problem solved
rickharris
rickharris
4 years ago
More information?
Premier what?
Load into what?
