190Views8Replies
Author Options:
Problem in Uploading to Arduino Dicimila Board Answered
Hi i m using Arduino Dicimila For my project. When i upload programs i got Error with this Msg::::Binary sketch size: 2380 bytes (of a 14336 byte maximum)avrdude: stk500_getsync(): not in sync: resp=0x00avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51Before that i done many uploades :), I've selected correct  port and Board... But still uploading problem...Can anyone help me to over this...?
Tags:Arduino
Bot1398
Bot1398
9 years ago
You might have not installed the drivers for arduino install them and it shoul work
astroboy907
astroboy907
9 years ago
Try using a different USB port. My Mac does this all the time even if I select the right board and port (Usually for me I cannot use a USB hub, try directly plugging it into the computer)
sabari1000
sabari1000
Answer 9 years ago
Thanks for the Quick reply :). Now i tried the other USB Ports also but it remains the same. Not Uploading :
astroboy907
astroboy907
Answer 9 years ago
hmmm, have you ever taken the chip out? I put mine in backwards once and I'm pretty sure it gives the same error :)
sabari1000
sabari1000
Answer 9 years ago
Yup.. i too took out the chip and and placed a new chip correctly :) :)
astroboy907
astroboy907
Answer 9 years ago
if it is a different chip than you usually use, it may not have the bootloader installed, or it may be a newer version of the bootloader. Try setting the board to an Arduino Uno
Libahunt
Libahunt
9 years ago
Have You tried holding down reset button at the same time You click "upload" in the UI? I have a foggy memory it might have helped with my Duemilanove once, but I did not take a good note really.
Also restarting the computer is always worth trying.
sabari1000
sabari1000
Answer 9 years ago
Ya... i did Holding RESET for a time,while Uploading but it increased the Uploading Time and finally Shows the Error...!
