89Views12Replies
Author Options:
Problem with a 30-0-30VDC @10amps transformer/SMPS and 400WATT RMS mono amp(not PMPO) Answered
First of all thank you so very much, i have successfully build my rectifier but now i am having a problem with it. Can a 30-0-30VDC @10amps transformer/SMPS, power a 400watt-RMS car sub @4ohms with a 400watt-rms mono amp. When i tested the 400watt subs, the gain is too low or am i doing something wrong here.
This is my 400watt-rms amp...
https://photos.google.com/photo/AF1QipONhTIOOnP8U687FDjOuiDSncup5C43T-i9IVfk
https://photos.google.com/photo/AF1QipO3N4hMdLNHFyXsTngmMNPuHCaouWW9LfA_hUqV
Thanks much, appreciated.
steveastrouk
steveastrouk
Best Answer 4 years ago
Have you got any pre-amp ?
Lima79
Lima79
Answer 4 years ago
OK you meant a Tone Control yes(:
steveastrouk
steveastrouk
Answer 4 years ago
A non-power amplifier, yes, one that could adjust tone too, but really a voltage amplifier.
Lima79
Lima79
Answer 4 years ago
OK the "voltage amplifier" it was just out here(:
https://www.instructables.com/id/Voltage-Amplifier...
but i am little confused here, so i need to connect the
"voltage amplifier" to my 400watt rms mono amp to get the full output
power, to drive my Pioneer 400watt rms sub-woofer, yes. Thank you.
steveastrouk
steveastrouk
Answer 4 years ago
Exactly ! The PRE-amp changes LEVELS, the POWER amp changes power.
Lima79
Lima79
Answer 4 years ago
Thank you good brother, but i am still having problem getting a
45-0-45VAC-DC power supply and i don't get enough time to make one
myself): but when i get one and assembled my amp, i surely will post out
here, on this great site(:
Lima79
Lima79
Answer 4 years ago
Apologizes good brother as you know i am new to electronics and English is not my native language so i get confused(: anyways thank you, appreciated.
Lima79
Lima79
Answer 4 years ago
Apologizes good brother i am new to electronics, so i don't understand, what is a per-amplifire. Thank you.
Lima79
Lima79
4 years ago
So this is a pre-amp yes(:
https://photos.google.com/search/_tra_/photo/AF1QipOSETa-1XoWK6AfUb5AbmGcaiJ5QOIvvnuvnioK
steveastrouk
steveastrouk
4 years ago
Yes, you can get 600VA from the transformer, if your amp is reasonably efficient, then you should be good to go.
Lima79
Lima79
Answer 4 years ago
Thank you good brother, i really like to make a youtube video but because of lack of time i can't, maybe one of this days i will.
