110Views10Replies
Problem with pictures in slideshow.
I am having problems posting my slideshow. I added all of the pictures to my slideshow and none of them will show up. I think it has to do with the format of the pictures (.JPG) but I do not know if there is a difference between .jpg and .JPG. If anyone knows why please help me.
Here it is if you want to see the problem for yourself.
12 years ago
I suspect this issue may be the one we are referring to internally as, "slideshow edits don't show up immediately". If so, that should be fixed in the next site release, later this week. In any case, waiting a day should allow the changes to take. What's happening is that the old version of the slideshow is still in the cache, and not cleared properly when updates are made.
Reply 12 years ago
It's fixed, thanks
12 years ago
Hmm kitemans file name theory sounds like a good one, though sometimes stuff like this is tetchy about using caps rather than normal font for file extensions... As another though it could have been an issue with the saving process, try adding them again...
Reply 12 years ago
It happens with every thing I try to add on.
Reply 12 years ago
Try making a new slideshow, could be a little coding mess up...
Reply 12 years ago
It works check it out (it is very long)
Reply 12 years ago
Looks nice, I'll take a proper look and comment when I'm not as busy..
12 years ago
Here's a thought - have you accidentally added a double extension, vis: picture.JPG.jpg?
Assuming you use windows, use "My Computer" to find the folder with your original images in, then select details view.
In the name column, does it say picture.JPG or just picture?
If it is the former, try changing the name to just picture and then uploading just one image to see if it works.
Reply 12 years ago
It says just picture the only place I see picture.JPG is when uploading to instructables.
12 years ago
HELP!!!
