104Views5Replies
Author Options:
Problems with power supplies. Answered
i made a small circuit board which is a proximity sensor that turns on or off a small philips genie light(its a small white tubelight like light ).i tried powering it up with a 9v battery and it works fine and the relay on the circuit board switches the ac220v load and the light goes on ,however when i try powering it up with a 10vdc adapter the relay on the circuit board keeps clicking(here i have not used the ac load to switch the tubelight,i was just experimenting and came upon the problem) .what should i do .pls help me.
Lectric Wizard
Lectric Wizard
7 years ago
If the above answers don't work you may be drawing too much current from the adaptor. What is the rating of your adaptor -will say xxx mA,someware on the case? Relays can sometimes draw fairly large current as they pull in.
Josehf Murchison
Josehf Murchison
7 years ago
A lot of cheap adapters don’t have a cap on the rectifier so steveastrouk is probably right, I would add a single diode 1N5817 just in case there is a week diode in the adapter and as large of a 16 volt electronic cap.
steveastrouk
steveastrouk
7 years ago
Put a good sized electrolytic capacitor across the power input to your board. 470uF should be ideal.
Strontium
Strontium
Answer 7 years ago
does it act as an noise filter cap or as bypass cap ?can i use 100uf ?
oh and thanks for answering my question.
steveastrouk
steveastrouk
Answer 7 years ago
Here its acting as a "reservoir" capacitor, and holding charge when the nominally DC (but probably actually only rectified AC) dips. 100uF might work, but if the relay takes too much current, it might not be enough - put another one in parallel !
Steve
