2353Views8Replies
Author Options:
Programming an Attiny85 with Arduino Uno as ISP, but I keep getting Serial was not declared in this scope? Answered
The sketch runs fine on the uno, but as soon as I switch the board to Attiny 85, i get an error that says serial was not declared in this scope.
Any help is greatly appreciated!
Here is the sketch for reference.
#include <IRremote.h>
const int relay = 9; //Relay Control
const int RECV_PIN = 8; //IR Sensor
int relayState = LOW;
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup()
  Serial.begin(9600);
  irrecv.enableIRIn();
  pinMode(relay, OUTPUT);
void loop() {
  if (irrecv.decode(&results)){
        long int decCode = results.value;
Serial.println(decCode);
switch (results.value) {
        case 1637937167: // Power Button
      relayState = !relayState;
      digitalWrite(relay, relayState);
      delay(100);
irrecv.resume(); // Receive the next value
steveastrouk
steveastrouk
7 years ago
You can't use the SAME pins for Soft serial as the relay and the IR.
meanbean
meanbean
Answer 7 years ago
Sorry, I'm new to the softwareserial command. What pins should I set it to?
steveastrouk
steveastrouk
Answer 7 years ago
Any two other than two that are already in use for other things. Your other problem will be taking serial out to the real world - you will need a TTL serial to USB cable.
spiffomatic64
spiffomatic64
7 years ago
If you want to use serial, you will need to use softwareserial
http://arduino.cc/en/Reference/SoftwareSerial
You may need to modify the library itself (I seem to remember it having a hard frequency ifdef)
http://digistump.com/board/index.php/topic,212.msg1214/topicseen.html#msg1214
meanbean
meanbean
Answer 7 years ago
Still no luck, although I'm fairly certain i'm using SoftwareSerial wrong
#include
#include
SoftwareSerial mySerial (8, 9);
void setup()
mySerial.begin(9600);
void loop() {
mySerial.println(decCode);
delay(100);
Now I'm getting an error originating in the ir libraries.
steveastrouk
steveastrouk
Answer 7 years ago
See my comment below.
