98Views5Replies
Author Options:
Project Progress Answered
I will be updating my progress here of the project so you know if any of your mechanisms have been used or how its coming along.
oscarthompson
oscarthompson
11 years ago
Update: Astronaught installed 3rd august: Astronaught was painfully put it to a small space unfortully losing a foot.
oscarthompson
oscarthompson
11 years ago
Update Diagram of mission made 21st july
oscarthompson
oscarthompson
11 years ago
Update: Rough simulation tests 20th july Results Parameters Bottle Volume 6000 cc Diameter 110 mm Water Fill 2000 cc Launch Pressure 827 Kpa (120 PSI, 8.16 Bar) Nozzle diameter 22.0 mm Nozzle viscous losses 0.04 Dry mass 100.0 grams Coefficient of drag 0.30 Initial Velocity 0.0 m/s Launch Tube length 0.0 mm Launch Tube diameter 22.0 mm Results Launch and thrust phase Initial thrust 652.0N Initial burn acceleration 300.6 m/s2 (30.7G) Average acceleration 1067.5 m/s2 (108.9G) Burnout Burnout after 148 milliseconds Burnout Velocity 158.4 m/s (570.1 kmh, 354.3mph) Burnout Altitude 4.8 metres (15.8 feet) Burnout acceleration 1742.0 (177.6G) Drag force at burnout 8.8 newton (0.9kgf) Deceleration due to drag 9.0G Speed increase due to air pulse 71.7m/s Coast Drag-free coast 1278.8 metres to apogee at 1283.6 metres after 16.3 seconds Actual apogee at 113.87 metres (373.6 feet) after 3.60 seconds Crashdown Crashdown speed 23.7 m/s (85.3 kmh, 53.0mph) Total flight time 10.03 seconds
oscarthompson
oscarthompson
11 years ago
Update: Camera installed 20th july: I have donated my phone to put in the rocket. Even if the parachute doesn't deploy it will probably survive. It will be quite a rapid deacellaration. phones are made to be tough. The camcorder on it works and it will be in use shortly
oscarthompson
oscarthompson
11 years ago
Update: Parchute tests 19th July: Parchute deployed brilliantly payload to go in to the rocket soon. The recovery sysytem works. Thankfully there is a 2 sec delay for the parachut to deploy after recovery as it needs to unfold and open.
