118Views8Replies
Author Options:
Project ideas help? Answered
I have an 28v dc motor that i want to do something with. Does anyone have any ideas? It's a pretty big motor (weighs about a pound), I was thinking about making some kind of tool with it.  Any ideas would be appreciated. Thanks
iceng
8 years ago
Attach a 4' shaft with sleeve bearing and C-clamp.
Place a propeller on the end and have a trolling motor for fishing.
We can help with a minimalist dc speed controller
Make another ible while your at it.
A
musick_08iceng
Answer 8 years ago
i dont think the motor is big enough for that, but i do appreciate all the ideas. definately getting some good ones
icengmusick_08
Answer 8 years ago
How little is your boat ?
A
LargeMouthBass
8 years ago
Do you have any other specs on the motor, such as power, rpm, etc? Does it have an attache gearbox? These parameters will have a big impact on what you can realistically use it for.
musick_08LargeMouthBass
Answer 8 years ago
1/15 hp, 6 amps, 28vdc, 80 rpm. it has like a pulley attatchment at the end
kevinhannan
8 years ago
If you have a workshop you can make a flatbed circular sharpening disk. Pretty much you have a guaranteed flat circular surface spinning courtesy of your motor and you can sharpen your tools amazingly well with it by changing the grade of grit-paper. If you're curious about this, check the woodwork websites out and you'll se they are expensive but excellent. ;-)
iceng
8 years ago
Use motor to spin a 7" dia cardboard disk ( suitably attached to motor shaft ) with a single 1/4" hole in the disk on a 6" dia while looking through said hole at a fluorescent lamp and adjusting the motor speed until the color flicker of the lamp is made visible as it changes AC polarity by synchronous timing.
A
iceng
8 years ago
This attaches to the back of your dominant hand and vibrates.
So you can use your hand to give pleasant vibratory massages to people/
Can you make it ?
A
