650Views8Replies
Author Options:
Question about a flyback's polarity Answered
Hello,
I am confused with this flyback transformer I have.
I have a pulsed DC input on the primary coil (pulses from 0 to 15V) and that creates high voltage in the secondary coil.
When I connect that input in the opposite direction (wrong polarity) I don't get high voltage any more.
The possible explanation for this is that the primary coil has a diode in series with it.
Now, I'm confused by this because I tested if there actually Was a diode in there (by connecting a DC supply and a DC motor, in series with the coil) and the motor always works!
(also tested with a halogen light)
I put the coil in series with the motor to test if there is a diode inside. If there would be one inside, the motor should not work in one of the two cases, when I switch the pins of the primary coil.
So, as the results of the test tell me: there is no diode in series with the primary coil.
could it be possible that there is a diode in parallel with the primary coil?
If that's not possible, how come the flyback is not working when I connect the polarity incorrectly?
Could someone please help me out with this?
Thanks,
Electorials
steveastrouk
Best Answer 8 years ago
There's often a diode in the SECONDARY
Steve
steveastrouk
8 years ago
I don't live on IRC - if you see Lizzyastro on there, try pinging her.
The "instructable" is a work in progress - no pictures.
Steve
steveastrouk
8 years ago
EXACTLY !
Actually, di/Dt= V/L UNTIL THE CORE SATURATES.
Would you like to see my unfinished notes on FLyback action ?
iceng
8 years ago
Yea that's the case Lol
steveastrouk
8 years ago
No we don't because we switch it off pretty quick, or we WILL saturate the core.
Steve
iceng
8 years ago
Still much fun,
But really the varnish on a small pulsed transformer for residential use must dampen mechanical and magnetostrictive events not just quiet but silent..
The varnish does the job and has a low visible acrid stink if burned.that can
permeate a room..  Avoiding this smelly possibility the fly black transformer
is over designed which explains why they are a favorite among hobbyists .
steveastrouk
8 years ago
DC in a transformer will NOT have no effect - it will cause the core to saturate. You MUST NOT have standing current in the transformer.
icengsteveastrouk
Answer 8 years ago
Or acrid smoke will rise up and smite thy lodgings.
