211Views9Replies
RAM upgrade
Hi, I want to add this (samsung m471b5673fho-cf8) to my imac. I found it in a dead laptop and there is no sign of wear. Will it be okay to put in my imac?
Best Answer 8 years ago
Its compatible if that's what you mean. Will it work? Well that's another issue completely. It all depends on what killed the laptop the memory was originally in. RAM rarely, if ever, shows any physical signs of damage, but you won't know if they work or not till you try them out in the mac.
Answer 8 years ago
and its often a mobo that makes a stick of ram go bad...
...in rare circumstances a failed ram stick can damage a motherboard.
Answer 8 years ago
Can I test if it is good in an old 1990's laptop, or will that just show the laptop does not know what to do with a lot of ram?
Answer 8 years ago
It won't be compatible with the old laptop. The dims won't even fit in the slots.
Answer 8 years ago
So if the ram is good, there is no chance of my imac getting zapped? I want to use a cheap computer to test it is still good. My friend has old tower computers from 2000 will they make sure it is good?
Answer 8 years ago
First of all you need to know what you have. Your RAM is DDR3 and is in a SODIMM package. So you need a recent laptop that takes DDR3 RAM to test it. A SODIMM package is too small to fit in most tower PCs. Just plug it into the iMac. It will either work or it won't. You are more likely to win the lottery then you are to kill your iMac with a bad set of RAM.
8 years ago
The ram was good and my computer accepted the ram :)
8 years ago
THANKS y'all :)
8 years ago
Putting a part of another brand of laptop into Imac is kinda tricky because of the fact that Apple isolates itself in terms of products and technology. There are plenty of things to consider like the brands model and year it was made. Every year the technology is advancing and the sizes and slots differ every year. Try to get further information on stuff. For example, before i was having a big problem on having supplies for my inks but i tried looking up Ink Supplies Online and there i tried different suppliers and eventually i got what i need. You should always verify and check the latest information's online.
