89Views5Replies
Author Options:
RE CHROMING ZINC ALUMINIUM Answered
I am looking for info on how to restore zinc aluminum car parts . like the automobile horns they tend to oxidize AND do not stand up to the Chemical's when re chroming. I be-leave that there is a process that will give them, a coating that can be used that will take the chroming posses
Regards John .
Tags:Horns
Downunder35m
Downunder35m
4 years ago
IMHO getting chrome finnish will be extremely difficult.
Due to the alloy composition the normal galvanising won't work too well.
Back in the day I did the restauration as follows:
Remove all loose and flaky stuff with a stiff brush, using some degrease can help if there is oil or grease on the parts.
Clean with stainless steel wire brush (should be a new one to prevent conamination with foreign metals or dirt).
You want a brush that is not too hard so you won't cause any bad scratches on the metal.
The fun part is now to use fine sandpaper followed by a nice polish to get a mirror like finnish (where possible).
Now clean all surfaces with acetone and make sure you leave no fingerprints - gloves are a good idea here ;)
Pack if clean plastic foil and give away for chrome plating.
Otherwise you use a good varnish to cover and protect your finnish as chances are the chrome finnish will interact with the alloy over time and just corrode again.
Johnbowman
Johnbowman
Answer 4 years ago
Hi Downunder35
Yes it is very difficult the chroming tends to destroy the the part. I had some chromed & they treated it with a coating to take the chrome but i do not know what it was called. i think if it could be sprayed with a coating & then polished up it should work OK , but what could it be sprayed with ?
Regards JB
Johnbowman
Johnbowman
Answer 4 years ago
Hi Steveastrouk
Thankyou will give it a try Regards JB
