3128Views7Replies
Author Options:
RGB LED Strip matrix? Answered
Can I use connected RGB L.E.D. strips in rows to make a animate-able matrix? And what program do I use to animate it? I'm working on making a deadmau5 mask that lights up, so it has to be a portable unit as I would like to wear it to shows. Thanks :)?
showtacle
showtacle
7 years ago
I think we have a solution for you.
Check out the following video to see if it is what you are looking for: http://www.youtube.com/watch?v=S8nPihPglcM
You can find more at www.ledstripstudio.com
David
steveastrouk
steveastrouk
8 years ago
Any particular strips in mind ? The ones I have have around 30 leds/metre. What you're proposing is possible, the software I suspect you'd have to write, but its only stuffing images at 16 images/second onto the matrix, not too hard to create. The problem is more likely to be power ! They are not light consumers of it
downhillwondrboy13
downhillwondrboy13
Answer 8 years ago
Any RGB strip with the most amount of leds per meter. And yeah I was wondering how i would manage the power, and if I would need a heatsink. And any suggestions as to how I would write the program and what software I would use? I've never attempted anything like this before.
steveastrouk
steveastrouk
Answer 8 years ago
Start by finding suitable LED strips. 30/metre is the most I've seen in convenient strips. You shouldn't need a heatsink for the strips I've seen.
Writing the code is secondary to getting the LEDs, even an Arduino is probably fast enough to do basic animation on a small matrix.
You could do tricks like clock out multiple columns of data with the same instruction cycles, but if you haven't written any code, I wouldn't start from here. ;-)
