7841Views4Replies
RGB LED controller chip?
Does there exist an IC, which can flash RGB LEDs? I really like auto-flash LEDs, but I would like to have several LEDs flash (and change colour) in sync. But auto-flash LEDs, have different flash rates. Is there an IC, which can flash several manual control 4-pin RGB LEDs???
Best Answer 11 years ago
im not sure about just an ic, but the system i use is an arduino and a rgb led with a built in microcontroller. The led thing is called a blinkm and costs about $15. You program the controller using the arduino, and there is a graphical user interface to design the blink pattern. the leds are reprogrammable also. I was able to make my blinkm to blink out binary code for ZEROGX... it was pretty tight.
11 years ago
Here you can find what you need, only 1 chip:
http://www.bowin-ic.com.hk/icdatabook.html#10
11 years ago
there are a couple of chips and kits that can be used to drive RGB LEDs. There's a bit of free software (for non commercial use) at Pete Griffiths project site:-
http://www.picprojects.org/
And a more sophisticated chip available from my own site:-
http://www.bigclive.com/shop.htm
11 years ago
you can find circuit with similar chip in some keychain toys + you get small leds too the chip in there is directly on the board under a splash of plastic and cannot be removed. but you can cut the board around it to have only that part (carefull to not stress the chip)
