99Views6Replies
RGB LED strip help
Hi guys so i'm buying a 5050 rgb led strip and i'm connecting it to my arduino UNO
so my question is can the arduino power 2 meters long led strip
5 years ago
What power would the 2m strip need?
In general all loads should be connected through transistors, mosfets or in extreme cases with SSR's.
It is a computer not a switchboard ;)
Reply 5 years ago
2m would need 2amp but what will happens if i use 6amp ?
Reply 5 years ago
If you use the 6amp the LED strip will just shine the same way...
Reply 5 years ago
so you're saying if i use 6amp with rg led strip it will not burn ?
Reply 5 years ago
Nops, 6amps is the maximum current your power supply can provide. It does not meet that it will give out 6A all the time. Your LED strip will only pull as much as it needs. Meaning they will shine just as bright, as Downunder35m mentioned.
In most (if not all) RGB strips (or any other LED strips), there is a current limiting resistor which will prevent excessive current flow which can damage the strip.
Reply 5 years ago
are you there
