175Views3Replies
Author Options:
Rc airplane assistance. Answered
Ok so I am constructing a scratch airplane as some of you may have read on m other questions. I have reached another dilemma, whether or not a moving rudder is completely crucial. I'm thinking i could get away with just having a stabalizer fin in place of the rudder.
 Any help from you pros?
Thanks, Bud
AndyGadget
AndyGadget
Best Answer 8 years ago
Are you planning to have ailerons and elevator?  If so, you can get away without a moving rudder but it will be slow to respond as you'll be rotating it with the ailerons and banking with the elevator - The 'bank and yank' method - As opposed to yawing with the rudder and banking into the turn.  You'll still need a tailfin to maintain directional stability.
An alternative is the RET plane - Rudder, Elevator, Throttle.  RET is best used on a plane with a smallish wingspan compared to the length as it reacts more quickly.  I've made and flown a couple of Nutballs which are RET.  Easier to make and fly than more traditional shaped planes, very manouvrable and lots of fun.  Build plans are HERE.
Re-design
Re-design
8 years ago
I fly R/C and very seldom use the rudder. I don't fly pattern aerobatics but if I did I would use the rudder much more often though. Lots of planes are built and fly just fine without a working rudder but they have to have working ailerons and elevator..
rickharris
rickharris
8 years ago
If your going to use ailerons and elevator you may get away with just a vertical stabiliser.
Banking the aircraft and then pulling it round with the elevator.
It is more common to use elevator and rudder and no ailerons though.
Do you have a reason for this idea.
elevons are another alternative.
https://www.google.co.uk/#hl=en&safe=off&sa=X&ei=reRYUMvCEIrB0gWzj4CwDQ&ved=0CBoQBSgA&q=rudderless+RC+aircraft&spell=1&bav=on.2,or.r_gc.r_pw.r_cp.r_qf.&fp=de8927dea74cc9e9&biw=1920&bih=919
may be useful
