753Views5Replies
Author Options:
Reading 12 rows of data from an SD card every minute and storing the data into Arrays using Gboard pro Arduino Answered
Hi, I am working on a project that measures temperature and current, store it on an SD card (csv file) and send them to a website. I decided to sample the signals every 5 seconds and store the data to the SD card using time interrupt (TimerOne). My plan is to sample and store data for 1 minute and then read the sampled data from the SD card and store them into 2 Arrays i.e Array1 for temperature and Array2 for the current and send the data to the website.
Thus far I have managed to sample and store the data using the time interrupt. I also included a count variable in the interrupt subroutine so as to know how many times the interrupt has occurred. Since I am sampling and storing the data every 5 seconds and I want to read the data stored in the SD card every minute, so when count = 12 I would like to read  the last 12 readings (24 since its current and temperature ) and store them into 2 Arrays.   The problem I have is that I do not know how to read the data from the SD card and store them into two Arrays and would like your help.
Note: the Reading of the SD card will not be in the Interrupt subroutine
Any help or suggestions will be highly appreciated.
Thanks
Muundu
steveastrouk
steveastrouk
5 years ago
How did you write the data TO the SD card in the first place ?
muundu
muundu
Reply 5 years ago
Hi steveastrouk,
Thank you very much for the reply.
I stored the data into two columns in each row in the CSV file.
e.g
Temp,current
12.5,5
10,20
3.24,21.63
2,3
and so on
steveastrouk
steveastrouk
Reply 5 years ago
no, what CODE did you use to write your file to the card ?
muundu
muundu
Reply 5 years ago
this is how i initialized the timer1 to occure every 5 seconds
//initialize timer one interrupt
Timer1.initialize(5000000); //interrupt every 5 seconds
Timer1.attachInterrupt(Logger); // logg data n every 5 seconds
this is the function i call every 5 seconds ( reads the sensor values and write to the SD cards)
void Logger(void)
blinkCount = blinkCount + 1;
//Record temperature
float Temperatures = analogRead(0) * 0.33; // Temperature
float probe_Factor = (Temperatures * 0.0001 );
// CALCULATE GICS
float GIC = (3.3/1023.)*analogRead(1);
float GICs= (GIC-1.5)*(3./1.5); //GICS
float GIC_Reading = (GICs/0.1);
// Serial.println(GIC_Reading);
dd= GIC_Reading;
String dataString = String(Temperatures )+","+ String(GIC_Reading);//convert to datastring for csv file
//*****************************log to sd card****************************
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
File dataFile = SD.open("datalog.csv", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
// print to the serial port too:
// Serial.println(dataString);
// if the file isn't open, pop up an error:
else {
Serial.println("error opening datalog.txt");
steveastrouk
steveastrouk
Reply 5 years ago
Then you need to look at the instructions for your file system
I expect there to be a corrolating function
File dataFile = SD.open("datalog.csv");
and then char=dataFile.read()
You'll have to assemble the chars into a buffer and then use atoi probably to turn the buffer contents into numbers for storage. Since your file has lines in it, look for the ',' character to find the end of the first number, and then final <enter> character to finish the line.
