176Views3Replies
Author Options:
Reciprocating motion? Answered
Dear All
I would like to imitate for to build a bar go up and down in angle 90 degrees  at website:
  - http://www.alivola.it/00-CLOHE-EN-oscillating-lever-1.htm
  ( oscillating lever 1 : animation )
So please help me to know  how  calculator  to find point C  ( CRANK 15mm) for the rod go up and down in angle 90 degrees .Many thank you
                                                     Best regards
                                                           lam
rickharris
rickharris
Best Answer 4 years ago
The animation you point to rocks back and forward.
You ask for the lever to go up and down by 90 deg, should I I assume you mean from horizontal to vertical? or will 45 deg either way be enough?
See diagram. It is easier to pull the lever up rather then push it up.
The arrangement is the same the distance between the lever centres in the 2 positions will be the same as the diameter of the wheel.
lam
lam
Answer 4 years ago
Dear rickharris
Your help and picture very very helpful. Thank you a lot
for your time help me,
rickharris
rickharris
Answer 4 years ago
Your welcome. Good luck. Patience and experimentation will get you there.
