126Views8Replies
Author Options:
Rectification of line voltage? Answered
I need to get 230V DC for controlling the brightness of the bulb using a mosfet transistor. The problem is that the rectified line voltage'll get 230 * sqrt (2) = 325 V .. it is too much. I didn't find a transformer AC / AC 230/160 V or step-down IO DC / DC 320/230 V on a market. How can it be solved? Sorry for my english. Thank you for answer.
AntonínO1
AntonínO1
5 years ago
I think I figured it out. I simply rectified voltage but not filter it with capacitor. And use high PWM frequency to avoid interference with the ripple voltage. So it ll be OK for lamp.
AntonínO1
AntonínO1
5 years ago
I have a good reason, this is why I ask!!! I have to use controller SIMATIC S7-1200 por PID regulation of temperature, source of heat is IR bulb. I created a circuit with a triac, but the PWM signal must be synchronized with the phase voltages. I also created a circuit with detection of zero crossing. However, the controller is too slow to make it usable. When i dont want to use another microcontroller, there is a simple solution with a rectified source. Can someone please just answer my question?
-max-
-max-
Answer 5 years ago
If you need a transistor to switch in phase with power, you could always capacitively couple a wire to live wire and have that go into a analog input of a microcontroller. It is a getto solution but it might be an option.
steveastrouk
steveastrouk
5 years ago
To run a triac ZVC, use a MOC3021 optoisolator. The ZVC is built in
AntonínO1
AntonínO1
Answer 5 years ago
But it's still not exactly the happiest solution.
Downunder35m
Downunder35m
5 years ago
Why is it that people with obviously no clue have the need to risk their life playing with mains voltage?....
kelseymh
kelseymh
Answer 5 years ago
In the end, it raises our group average :-)
iceng
iceng
Answer 5 years ago
+1
