483Views16Replies
Author Options:
Regarding bristle-bots.? Answered
All the bristle-bots I have seen thus far have used offset, rotating masses to generate the vibration. I have just acquired a motor with a vibrating linear output. What direction should I point the motion for the most efficient bristle-bot? Front-to-back, or up-and-down?
tomman
tomman
10 years ago
i do not think it maters but i could be wrong
shawntherobot
shawntherobot
11 years ago
i would put them back to back at an angle
LinemenOwn
LinemenOwn
11 years ago
definitely up and down because the forward movement is caused by the angled bristles being pushed down and then as they push back to their original position the whole bot is sprung forward.
Wasagi
Wasagi
11 years ago
 Somewhat unrelated, who did the first Bristle-Bot? I remamber seeing one on Make a while ago, and it was in the 5 min DIY section of November's Pop Sci, and there are a couple Instructables. Regardless, it still it really cool!
Kiteman
Kiteman
Answer 11 years ago
There is a surprisingly vehement debate over who invented the bristlebot.
My opinion is that it was independently invented several times.
Wasagi
Wasagi
Answer 11 years ago
 Hmm, that would make sense, like domestication and what not, in isolated pockets based off the vibrobot.
Wasagi
Wasagi
Answer 11 years ago
Well, EvilMadScientist Was inspired by Make which then inspired make, as well as TheSpeakerGuy , which, in turn, Make linked to. Huh.
Also, i realized that I haven't been helpful at all, so, here's my opinion:
I would assume Top to bottom ( As in, it rotates on a vertical axis as compared to teh rast of the BristleBot), becasue it puts th motion behind the slanting bristles, where the weight wants to go anyway.
I hope that I neutralized my non--help! (Or Helped...)
Ervineng
Ervineng
11 years ago
when i made my bristle bot i used front to bck and i used a vibrating motor from a game controller i dont know if its a linear output but i put it front to back it moved very well i actually used it to clean a frying pan just for S@#$ and giggles once again i dont know if those motors r linear but if u find out they r i guess you got your answer so couldnt be mroe help and good luck with the ible
CameronSS
CameronSS
11 years ago
I would tend to think angled in the desired direction of travel. That way it will bounce the thing up a bit to get the bristles up, and will nudge it forward. If you mounted it on a hinge of some sort, you could play with directions until you found an ideal angle.
steveastrouk
steveastrouk
11 years ago
cor, where did you get that variant from ? Not seen them. Picture ? Thanks !
Kiteman
Kiteman
Answer 11 years ago
Pictures will have to wait until the Instructable.
dombeef
dombeef
11 years ago
What do you mean? "Front-to-back, or up-and-down?" But you should put it side ways so it will push itself
Kiteman
Kiteman
Answer 11 years ago
Front-to-back being back and forth in the direction of movement.
dombeef
dombeef
Answer 11 years ago
Oh ok well you should put it at a angle so will it cause it to jump a tiny bit and it might move
Bigev
Bigev
11 years ago
Up and down. Definitely. That way, the weight going up will cause it to jump a tiny bit, and thus provide a way for the bristles to move it forward.
