384920Views82Replies
Removing Gorilla Glue From Skin
Has anyone found a way of removing the brown 'Original' Gorilla Glue from skin. Earlier today I picked something up by the wrong side which I'd just coated in the stuff.
I've just spent 20 minutes washing and scrubbing my hands as per their FAQs and have just about lost the stuff, but has anyone come up with a miracle way of removing it?
Note that this is the brown foaming polyurethane glue; not the cyanoacrylate type.
Best Answer 9 years ago
Acetone, when its wet. Wear and tear when its cured.
Answer 9 years ago
Is that from experience, Steve? Their FAQ for the polyurethane glue says specifically don't use acetone as it removes oils from the skin and makes the glue more likely to stick.
Answer 9 years ago
That's from (bitter) experience.
We always have nasty solvents available, and acetone works very well. Yes, you should moisturise afterwards, and really, with a priori knowledge, wear a barrier cream on your skin to stop it sticking !
Answer 9 years ago
I finally tried this and yep, it works. In the absence of industrial solvents I raided my wife's cosmetics drawer for the nail varnish remover which also contains skin conditioner which I think helped the removal (and it left me with lovely silky skin afterwards #;¬).
3 years ago
I've used Gorilla Glue (the kind that dries yellow) on many things and it sucks! It drips all over the place instead of where you apply it. Then it sort of expands. It doesn't glue anything well for long and everything I put it on that came apart, I just peeled it off like a scab in pieces.
I just used what I had left in a small bottle to glue the plastic weight pieces from the underside of a large stand fan base. The weights are solid pieces when new but if you accidentally step on the wide circular base they crack and fall off. I repaired it once but it broke again so I just used the remainder of the glue to glue the pieces back in.
The glue is better at plugging the spout and preventing it from dispensing. It also glues the twist top to the bottle but you can loosen it with channel lock pliers which I did. Rather than trying to push the now thickened old glue out the spout, I just scooped the glue out with my finger and spread it on the pieces I was gluing. Eventually, I had glue all over both hands from the struggle of getting the pieces to fit back in the base.
I've worked with super glue and they recommend petroleum jelly and a razor. Some recommend soap and water.
First, I used a Lava soap bar and water before reading that water makes the glue harden. The soap made my hands slippery and made me think it was coming off. But when I rinsed my hands, they were still sticky.
So I tried my orange mechanics' hand cleaner. That did about the same as the Lava.
Then I tried a rag soaked in gasoline. That helped a bit but I was still sticky.
So, I used petroleum jelly and rubbed it in for a few minutes and wiped it off. Still a little sticky.
Then I used Dawn dish liquid which is great for getting almost anything off greasy parts and hands. I only used the Dawn without water and massaged it for a bit, then washed it off,
It worked quite well. I just wonder if I had used it first if it would have worked as well.
Each substance removed a bit of the glue but most left my hands sticky.
I HATE GORILLA GLUE! IT DOESN'T GLUE ANYTHING except the spout cap to the spout and makes a mess. There has to be some glue that actually glues things together, but Gorilla Glue isn't it.
Answer 2 years ago
So my husband after not finding the wood glue used a bottle of this satanic substance to fix a door. Pretty much follows your experience to a t.... no offense intended here, but now that I’m not frantically scanning new posts for some sort of act of god to get this off his hands, I’m dying!!! Absolutely dying!!!! Especially at how EXACTLLY your post relives what just happened in my house!!!
3 years ago
3 years ago
If gorilla glue is still wet, just use Pam cooking spray with olive oil, or straight olive oil, but the spray is neater.
4 years ago
I had a situation the other day similar to the original poster (OP)..picked something up wrong-sided and...it was over from there. I'd ended it up on the palms and fingers of both hands before the project was done (once it was on one hand I basically said f*ck it knowing I'd have to deal with it on at least one of my hands already).
Long story short, I tried EVERYTHING listed previously short of gas and brake cleaner or WD-40 but those were next on my list if I hadn't come to the solution I found.
I can say the Acetone, hydrogen peroxide, simple water and soap, gritty soap (like the kind mechanics use - my boyfriend is a mechanic so we have the "real deal" when it comes to this soap), etc. made NO DIFFERENCE.
Then as I was walking by my closet where I keep my paint supplies (AND SANDPAPER) I recalled the sage advice of the posters before me who mentioned sand and "wear and tear." I thought, let's speed up this process a bit, shall we?
100 grit (so really fine) sand paper did the trick. I went through one small piece between both hands and my hands are LOVELY smooth (but not injured or scratched harmfully in any way).
Next time, I'll go right for the sandpaper. :p
I hope this helps the next person! (as much as I really hope there's not a next person..haha) :)
4 years ago
6 years ago
I would try feathers first. If that doesn't work then little shredded up bits of cotton ball should do the trick.
Answer 4 years ago
ryantate777 ~ That is hilarious!
6 years ago
My daughter Gorilla Glued her armpits. When I asked why she said "to stick the pictures on". She generally tends to be ahead of the fashion curve, fyi. Now working through the various solutions presented here. Obviously the sage wisdom "don't do it in the first place" isn't too useful at the moment. But some ocean swim and time may be the one that works best. I do hope that she's learned something about strong poly adhesives!
Answer 4 years ago
I'm sorry about your daughter's situation but, I really found it very humorous! Could not stop laughing! I have 6 kids and the phrase, "Kids do the darndest things!", has always had me scratching my head, "Why? Why?! Really??!"... Gotta love them kiddos!
Answer 5 years ago
Thats absurd....
Answer 5 years ago
Thats a kid!
4 years ago
I tried water and soap and that just spread it, so I went and grabbed some damp sand from my kids sandbox and scrubbed my hands with it. Worked like a charm!
4 years ago
Just a follow up on my comment from 10 hours ago. As I said no liquids I tried from brake cleaner , carburetor cleaner, gasoline etc., etc. had much effect. I found a rough pumice stone scrub followed by soaking in vegetable oil for a full hour then pumice stone again removed 99 percent of it. And yes I have latex gloves on my workbench thank you ...
4 years ago
yesterday I wiped my hands in a shop rag with Gorilla Glue on it, and it dried. I have tried the entire spectrum of liquids and no luck. Today I am having progress with a pumice stone but very slow, be careful this is a sticky situation
4 years ago
In blind panic we tried petrol. This worked, then used washing up liquid then moisturised well.
5 years ago
I got some of this lovely substance on my fingers when gluing an ant moat to a hummingbird feeder. First I tried alcohol and that didn't work. Then tried acetone nail polish remover and that didn't work. These just made it stickier. I got a pumas stone and sprayed my hands with WD40. Used a thin dish scrubber with the WD40 and got it all off. So sounds like the olive oil or vegetable oil would work also.
Answer 4 years ago
DIDN'T WORK
4 years ago
After 20 minutes of panic during which NOTHING worked (I tried Swarfega, 99% Isopropyl alcohol, Acetone varnish remover, washing up liquid, soap and water - all of these seemed to make my hands stickier), I found this thread (I now also have a vey sticky keyboard). I can confirm that olive oil worked like magic!
4 years ago
Thank you everyone for all the tips. I'd let Gorilla Glue dry on my fingers a few minutes as I was fixing the sole of a shoe. First I tried soap and water (nothing), then olive oil briefly, but it wasn't instant. I tried nail polish remover for a minute (it helped a little). Then I came back to the olive oil, and let it sink in as I massaged my finger and gently(!) tried to scrape it away. About 10 - 15 mins. later all was off, I hadn't thought it was possible. The encouraging results in the comments helped me persevere and hope that it would actually come. And now, I have lovely moisturized hands :).
5 years ago
I ended up with it on my thumb and pointer finger. I sprayed them with cooking oil and used my coppery looking wire scrubby under water. It was gone in a minute! Might have been a fluke, but it worked!
Answer 4 years ago
thank you this helped me a lot and now my fingers are very soft
Answer 5 years ago
Just tried this and it worked famously for me. I used olive oil.
Answer 5 years ago
I had it all over my hands and couldn't get it off for 30 minutes. Olive oil worked like a charm. Acetone (nail polish remover did nothing and neither did "grainy" automotive soap. Olive oil is definitely the answer. Thanks!!
4 years ago
do this three times just to be sure
4 years ago
I just got a little on my hand and i tried using olive oil and warm water after about one minute of oil on your hands wash it with warm water once it is off wash with warm water and soap it really woks just rub the oil in there is many below this but this is the one that worked for me
6 years ago
here's a funny but weird story I'm almost embarrassed to tell the story my gorilla gluedried up so I figured if I put in the microwave for about 1 minute that wouldn't harm it because I was trying to replace the magnet on my glass door to my entertainment centeranyway I put it in the microwave and I pressed 100 or at least I thought I pressed 100 equivalent to 1 minute I turn my back and for 1 minute and realize the microwave was still goingthe time I was on the number 8 so I hurried up and opend the doorbut of course gorilla glue was everywhere in the microwaveby me not thinking I quickly grabbed it out of the microwave and of course that gorilla glue was hots and so now I've been sitting here for about how would say 3 hours trying to get thisgorilla glue off my handsso far I've tried just about every suggestion on this page the olive oil has work the best for me I just have to finish peeling it off...I know one thing's for sure I will never try that againand you have Gorilla Glue get hardened and dry eyes just so good in some hot water don't try the microwave lol lol
Answer 4 years ago
@ least you know it works, just make sure you press the right #'s next time, wish I thought of it, or read this 1rst, I just pulled out the chunks of dried glue with plyers & spent some X getting it off my hands.
Answer 4 years ago
I did a much worse thing, I heated it in the micro for 30 seconds and squeezed the bottle to see if it softened up at all and it squirted out on my arm and I tried to wipe it off cuz it was hot and it hurt and my skin came off too. I still have some of it on there and it is like a burn, it really hurts.ouch in more ways than 1??
Answer 5 years ago
No offense but that is a special kind of stupid XD.
4 years ago
Got my gorilla glue off by scrubbing my hands with a nail brush and a cleaner calledBAB-O then I shaved them with a disposable razor. It took a while because my hands were covered in dirt and gorilla glue. I should of took a before and after pic. At first I used acetone but that won't work alone. Fill a sink with BAB-O, scrub, soak then shave, over and over but it will work. Thanks for the help.
4 years ago
Many thanks to the people who posted. A combination of canola oil (I didn't have olive oil) and a brillo-like pad got the glue right off my fingers. I never would have thought of it on my own, so THANKS.
5 years ago
following up on the comment that using a razor blade to scrape it off, I tried using a zester (which for those who do not cook is a kitchen tool to scrape the outer skin off citrus such as lemons and limes for flavoring food). It was easy to control and worked like a charm
5 years ago
I FOUND A SOLUTION. I had my hands COVERED in dry gorilla glue, after hours of soaking and scrubbing with no luck I tried a razor! I literally shaved my hands with a Venus Embrace razor and it completely removed the glue!! Just soak your hands in warm water then rub the head of the razor back and forth pressing the blades against your skin, this will not cut you as long as the skin is taught. Sounds scary but, trust me, it works!!
5 years ago
I tried just about everything..Acetone, double D 40, paint thinner, sandpaper, etc.....The pads of my fingers were stained.....Finally I used Brillo pads, wet and soapy and Comet...It WORKED! No damage done either....After, I used olive oil and a bit of sugar and then rinsed and dried my then soft hands.........This stuff scres the devil out of me...Not sure I will use it ever again!
5 years ago
Thanks for all the advice, I found that the olive oil didn't work well, I hadn't tried the acetone, but the brillo pad with suds warm water and some scrubbing did work, that stuff is tuff. Hope this helps someone else.
5 years ago
I didn't want to use acetone because I have pink and white (french manicure) gel nails and the acetone could ruin the finish and I just had them done two days ago. So, I tried the olive oil that several people recommended, put it on a paper towel, rubbed it on my hands and under my nails and it WORKED like a CHARM!!! I totally recommend using the olive oil to remove Gorilla Glue. Good luck and many blessings!!!
5 years ago
5 years ago
Help me
5 years ago
how do i get this stickey glue off my hands it is gorilla g
5 years ago
I just got the gorilla glue on my hands and I tried some Comet bathroom toilet bowl cleaner and I squished my hands together for about fifteen seconds with it on the hands. I then added the counter liquid bath soap I had and then rinsed with water. The first attempt took care of a lot of it, but some still remained. I repeated the process and then rinsed again. They felt much better-not sticky feeling.. I also used hand lotion after this and now my hands are soft and no sticky residue. It might not be the best combination to use, but it worked for me. I'll keep my hand lotion handy to apply if needed.
5 years ago
5 years ago
Hey there,
I got gorilla glue on my hands and of course I didn't want to touch my computer with sticky fingers so I couldn't look up the acetone solution. Now that the glue has dried, the only thing that got it off was time and soaking my hands in warm soapy water. After letting them soak for a few minutes, one hand at a time, I was able to just scratch the glue off. Hope that helps!
5 years ago
A good scrubbing with a wet Brillo pad removed the Gorilla glue stains on hands. Acetone (nail polish remover) didn't work.
5 years ago
Rubbing alcohol
Don't say it don't work because my mom just did it like two minutes ago.. Nothing else was working n I suggested it n it makes it peal right off like Elmer's glue lol
6 years ago
After trying many solutions, with no success, I read the post about using sandpaper. That reminded me that my sister had given me a "micro-pedi nano" for Christmas that I had yet to open. I used it on all 5 fingers that had Gorilla Glue on them and it worked! I may not have any fingerprints left, though... :-)
