2826Views7Replies
Author Options:
Replacing LEDs on a LED fan? Answered
If the LEDs are the same voltage, can i just cut the wires on the LED fan, and just simply re-solder the new LEDs onto the wires? I have been looking at several Instructables about replacing the LEDs on a fan, and they all have complicated re-wiring ideas..Can't you just simply replace the LEDs with the news ones?
frollard
frollard
Best Answer 11 years ago
notably uv, blue, and white use more volts than red green and amber. So - you can replace red, green and amber interchangeably - as with blue/white. Otherwise you may need to change the resistor used for that particular led.
ramroids55
ramroids55
Answer 11 years ago
Well, the LEDs i want to replace them with are Auto-Changing RGB LEDs..and from what i have found from the manufacturers website, they are the same voltage..so it should be a straight replacement
frollard
frollard
Answer 11 years ago
Each led on the original fan will have its own resistor if it's designed properly - and to run on 12 volts each will get a different value... or... they put them all in series then made sure the voltage drops added up to 12 (plus the resistor drop)
ramroids55
ramroids55
Answer 11 years ago
I replace them, and they seem to work perfectly fine. Auto changing fast-flash RGB leds look really cool in a fan btw
frollard
frollard
Answer 11 years ago
Great job! Video and instructable it!
ramroids55
ramroids55
Answer 11 years ago
I plan on it =]
Jayefuu
Jayefuu
11 years ago
Yes you should be able to. If they're the same LEDs you needn't do anything fancy.
