14509Views6Replies
Replacing capacitors with different rating?
Hi! I am trying to repair a computer monitor....it has 2 capacitors that are blown. I have a replacement for the first one, but not for the second one.... My question: On the capacitor it says 330μF 25V, can I replace it with another type of capacitor? Wich number is important, the "μF" or the "V"?
Best Answer 9 years ago
They are both important. The 330uF you should stick to the same value. But the 25V is the voltage rating that the cap can handle. You can use one with a higher V rating but not one with a lower V rating. So a 330uF 50V will suffice. But a 330uF 10V will be a problem. The uF is the capacitance of the capacitor and was chosen by the designer for a particular reason. The circuit may not operate correctly with a different value of capacitor. The Voltage rating is the voltage the capacitor can handle.
Answer 9 years ago
Thank You very much for the answer!!
10 months ago
Can I use 330uf capacitor instead of 220uf capacitor?
1 year ago
Can I safely replace a 100uf 50v with a 100uf 100v
Reply 1 year ago
Absolutely.
As was so nicely explained above, the voltage rating is simply the maximum voltage the capacitor can safely handle.
Think of it like buying 150km/h speed rated tires to drive on 100km/h speed limit roads. The tires don't care if you're only driving at 100km/h or 10km/h, they'll still work fine and you'll have a large margin of safety.
So why not just use a bunch of 300v capacitors for everything in a household electronics item and save all the hassle?
A) money. In general a 20v 5uf will cost less than a 300v 20uf capacitor so if your circuit is say 12v then it saves money to use the lower rated capacitors.
B) size/space. The lower voltage rated parts after often smaller at the same capacitance (uf) rating and of course these days manufacturers are trying to keep things as small as possible.
In your case this may also affect whether the replacement fits or not in the same space as the original.
1 year ago
To Josemech
Yes! Nice explanation of capacitor values by "theland of the dave" in this thread
