532Views5Replies
Author Options:
Resettable Fuse PPTC Polyswitch instead of normal fuse? Answered
Hello Friends,
I have basic multimeter which has 250ma 250v fuse in it.
some how due to bad test it fused due to higher amps.
now I am planning to replace it with 250ma 250v Resettable Fuse or PPTC or Polyswitch.
can I go for it or it may create problem?
any body have tried?
steveastrouk
4 years ago
Fuses blow MUCH faster than polyfuses. That's why meters aren't fitted with them.
icengsteveastrouk
Answer 4 years ago
+1
Even though one can find 300v 100ma polyfuse Steve is correct no meter ever uses them.
Downunder35m
4 years ago
Forgot to mention: If you constantly blow the fuse in your meter you are doing something wrong with your measurements!
You can't fix operator faults with fuses ;)
Downunder35m
4 years ago
You want ultra fast fuses for a meter.
Never use slow fuses or even poly's, if there is problem you want the fuse to blow and not the electronics inside your meter.
