2219Views3Replies
Author Options:
Resistor for SMD LED 1306? Answered
I'm struggling to find any clues of what kind of resistor to use as I am a little new at this kind of project. I'll be using the lights in a small scale 9v project for up to 100 SMDs.
I'd appreciate any advice!
Cheers :)
Downunder35m
Best Answer 4 years ago
You need to know the max current of the LED and the rated voltage for the LED.
9V - LED Voltage / current of the LED = Resistor value.
As a personal rule of thumb I prefer to stay slightly under the max rating for LED's to increase their lifespan.
As an example:
Voltage for the LED assumed to be 2.3V and a max current of 15mA:
(9V - 2.3V) / 0.015A = 447Ohm
At 470Ohm it will be 14.25mA
At 500Ohm for the resistor the current will be reduced to 13.4mA
Next higher standard value would be 560Ohm and 12mA
Wired_MistDownunder35m
Answer 4 years ago
If you are running up to 100 of these led's why not wire them in Series?
Wire a group of three LED's in series with a 150-Ohm resistor !
Downunder35m
4 years ago
How else do you want to write it correctly with no unicode supported?
This is the way it way always done ;)
Without access to grrek symbols here it has to do.
-max-
4 years ago
I would assume they will work plenty bright at 15mA, so I would use that figure, then you need to know how much voltage drop across the LED is to figure out the perfect resistor. You can do that with a potentiometer and a few multimeters, (to measure voltage and current simultaneously) or just refer to the datasheet for the numbers.
-max-
4 years ago
You can always just use a 1K resistor. That will be fine.
In this video, I have included a guide about 2/3rds the way through a guide on calculating the exact resistor to use to get the most power out of the LED without overdriving it.
