90Views6Replies
Author Options:
Resistor value? Answered
I'm making the circuit attached, can anyone help me with what resistor value (marked by "?"). What value will need when I connect 2 UV LEDs into the circuit. The pack says LEDs are 3.1V.
Any help would be greatly appreciated...
Josehf Murchison
Josehf Murchison
7 years ago
Check out my Instructable on Photo Components Testing.
https://www.instructables.com/id/Photo-Components-Testing/
Josehf Murchison
Josehf Murchison
7 years ago
Most UV LEDs run on 10ma so 9/.01=900 you should be good for 1 k ohm.
steveastrouk
steveastrouk
7 years ago
We need the forward current. If we say its 20mA, then the R, for a 9V supply is (9-(2x3.1)/0.02 = say, 290 Ohms.
KJ4ZVQ
KJ4ZVQ
7 years ago
According to my mathin'.... you could put 3 volts to each with a resistance of 60 Ohms. Being a strange value, you would probably need 6 10 Ohm resistors in series to achieve this. Hope this helps, and good luck!
mpilchfamily
mpilchfamily
Reply 7 years ago
What forward current are you assuming the LEDs have? Most UV LEDs i've seen have a forward current of 30mA. Your calculation seems to account for a forward current of about 50mA.
mpilchfamily
mpilchfamily
7 years ago
It all depends on what the forward voltage of the LEDs are. Look up one of the many LED calcs that are available online. Plug in how many LEDs you have, the source voltage, the forward voltage of the LEDs, and the forward current of the LEDs. Then it will give you the resistor value you'll need.
