260Views7Replies
Author Options:
Reusable Burst Disc? Answered
So I had an Idea for something, but the problem is that it would need a burst disc or rupture disc, which have to be replaced after each use. What I was wondering is if there is some way to make them be able to be used multiple times, or something that could act like a burst disc (eg releasing a large amount of pressure very quickly) that could be used in quick(ish) succession?
bwrussell
bwrussell
Best Answer 4 years ago
You might be able to find some sort iris.
Kiteman
Kiteman
4 years ago
I have only seen vortex cannons driven two ways - a push from a diaphragm (have you seen the "Airzooka" toy?)
or a small explosion in a chamber at the rear of the cannon.
iceng
iceng
4 years ago
A stiff oblong disc held against an oblong channel and then rotated a with magnetism past a tripping point to swing free.
iceng
iceng
4 years ago
Pumpkin Cannons use ball valves...
steveastrouk
steveastrouk
4 years ago
The ball valve, if you can whack it fast enough, is pretty effective.
Mecknavorz
Mecknavorz
Answer 4 years ago
I'll keep that in mind, but is there anything flatter, becuase I'm using it to make a vortex ring gun, and I think a ball valve might throw off the airflow
steveastrouk
steveastrouk
Answer 4 years ago
I wouldn't have thought you needed to move enough volume of air for a vortex gun to need more than a movable diaphragm
