104Views7Replies
Author Options:
Rotational Charger? Answered
Any ideas how one could transform rotational movement into usable energy?  I want to attach a little radio device to a tire and have that device charge a little battery when the wheel rotates so that it can transmit information (i.e. rpm).  Was thinking of using a small Nordic radio and accelerometers to transmit data.
Tags:charger
steveastrouk
steveastrouk
10 years ago
Put a magnet on the fixed part and a coil of wire on the rotating part, in line with the magnet.
lemonie
lemonie
Answer 10 years ago
Other way around?
You'd want your "stuff" on the stationary wouldn't you?
L
steveastrouk
steveastrouk
Answer 10 years ago
My way I think, he needs to power the rotating thing to broadcast back to the receiver ?
Steve
frollard
frollard
Answer 10 years ago
if he only needs RPM, he could use a hall effect or a coil and have the magnet on the rotor.
One could use the timing or analog voltage to calculate rpm/speed since faster= higher voltage.
steveastrouk
steveastrouk
Answer 10 years ago
True, I was reading this as on wheel sensing, you're right, its the other way round apparently.
lemonie
lemonie
Answer 10 years ago
You'd get a pulsed signal or otherwise-"frequencied", RPM wouln't be too hard from that?
I don't like the idea of "valuable-bits" strapped o a wheel with batteries.
L
orksecurity
orksecurity
10 years ago
The usual solution for bicycles is a magnet on the wheel and a reed switch which the magnet closes each time it goes past. Count closures per minute to get RPM. Cars, I believe, often measure this off the drive shaft rather than the wheel or hub.
