91Views5Replies
Author Options:
Rubberband gun shooter thing help Answered
I'm new so I'm not sure if I'm posting in the  right area but i need help. I'm trying to make a rubber band gun shooter thing but sometimes when i try to let the rubber band go it gets stuck. I originally used a metal piece with three angles and now im using a old allen rench. Normally when pulled back i use my hand to keep it steady but since i needed to take the picture i used a nail (probably not the best thing to use when stretching a rubber band), but anyways i was wondering if anyone had an idea to make the rubber band  ball thing always go off?
P.S.  need an idea for the wooden gun shape.
tan123
tan123
9 years ago
For the shape of the rubber band gun you could check out some guns on Google images, that's how I came up with the shape of my RBGs.
Goodhart
Goodhart
11 years ago
Not to interfere with RMS's answer,  but by "lowering" the allen wrench,  I am assuming he means, making the hole it fits in, deeper, so it is not so "highup" and getting in the way.
His idea of using a finishing nail is a good one too.....face it at an angle so it's head is away from the "shooter"  and it should work quite well
Sorry RMS,  I hope I didn't "step on your toes" with this post.
RavingMadStudios
RavingMadStudios
Reply 11 years ago
Yup, that's what I was trying to say. My first post that went poof was a little more detailed. Thanks for clarifying.
Vertox
Vertox
11 years ago
Thanks for the help, I'm going to try them both and see what works. i'll post  the results^^.
RavingMadStudios
RavingMadStudios
11 years ago
This is my second attempt at posting. The first one apparently went *poof*. Charm....
Your allen wrench is mounted too high. I'd suggest either lowering it so that it's flush with the wood, or replacing it with a finishing nail driven in from the front. Also, the forward-pointing end can be much shorter. Both of these changes should go a long way toward improving the release of the rubber band.
