82Views0Replies
Author Options:
Salami Fridge/ Fermentation Chamber Answered
I am trying to set up a salami / prosciutto fridge at home. This is good for everybody haha.
FYI
Salami needs certain parameters to correctly culture and age.
Day1 22-24C 95% Humidity
Day2 18-20C 90% Humidity
Day3 16-18C 85% Humidity
Day4 14-16C 80% Humidity
Day5 12-14C 80% Humidity
Day6 12-14C 75% Humidity
Day7 10-12C 75% Humidity
To Age 10-12C 75% Humidity
I have-
a domestic fridge which I have cut and fitted an exhaust fan in the front
a humidifier
a light globe (for warming)
a grey electrical box – holes cut and 4 single power points fitted.
a Lcd display and control board (from Jaycar) for the arduino
what it needs to do is the following
I want the control panel to have, temp control, humidity control,
I want the exhaust fan to run 1min every 4 hours – this is because ammonia builds up as a gas in the chamber, this needs to be removed via the attached fan
I want the humidifier, the light and the fridge to be controlled by the same “temp” control;
Ie
Day1
I set the fridge to 95% humidity and 24C
Light on to temp then off - or on/off as needed
Humidifier on to correct parameters then off - or on/off as needed
Exhaust fan comes on and the computer compensates this evacuation and temp/humidity is on
Day2
I set the fridge to 90% humidity and 22C
Light on to temp (or fridge cooling, depending on temp)
Etc.. etc..etc
Now this also means this needs to be adjustable via the little control box because some thicker sausage takes longer and thinner less… ie
Humidity
1=95%H 2=90%H 3=85%H 4=80%H 5=75%H
temp
1=24C 2=22C 3=20C 4=18C 5=16C 6=14C 7=12C 8=10C
Anddddd prosciutto doesn’t need this type temp/humidity drop. It only needs a stable 75% humidity and 12C
The idea is Ill have a sparkey wire up plugs into the humidifier, light, fan and fridge.. they all plug into my super sexy grey box that has 4 plug holes on it ( ill send you pictures)..
The inside of the box - a 4 switch relay... to power the toys
a connection and lead in that gives power…. And I have access to the liitle LCD screen to adjust the parameters when needed.
I assume I need to get more electrical/computer parts for this.. and the program written that controls all this info.
any info will be rewarded with salami.!!!!!!!
