3715Views15Replies
Author Options:
Sawdust as a medium for hydroponics? Answered
Actually I have 2 questions pertaining to hydroponics. First you should know that I have a passive hydroponic system functioning right now the container is partially submerged in a nutrient solution with holes in the bottom of the container. The medium I'm using right now is perlite to allow more oxygen and act like a wick. I do have a top layer of aquarium gravel to anchor the plant better. I've been thinking of trying to add more oxygen to the roots by using an air pump. I was going to insert the tube from the top (the dry section above the water) pointing down to the wet section to blow some air to the roots. Would this be an unnecessary addition if I continue to use perlite as a medium?
My second question is the title, would sawdust work as a medium for hydroponics? I assume it would be able to act like a wick for a passive system my concern is would the roots get enough oxygen in sawdust? Also most mediums are inert sawdust wouldn't be, would that have a negative impact on my plant?
canucksgirl
canucksgirl
Best Answer 8 years ago
Regarding your first question. Yes, you need to add oxygen, as the plants are absorbing it rather quickly. If the oxygen content of the water is low, it will slow the plant growth.
Sawdust can be used, but it should be from a known source. You don't want saw dust that contains paint, varnish or any other chemicals.
Here's a link to a Hydroponics Website that contains some good information for you. The page I'm linking you to discusses the types of mediums you can use. From the menu, I'd recommend the Articles. There is a lot of information there that you might find useful, particularly the one on oxygen
thecoonskin
thecoonskin
Answer 8 years ago
thanks, sounds like I should go ahead with my oxygen plan then. Could I use an electrolysis apparatus to increase the oxygen level in my solution? I was thinking of having a 5 gal bucket filled with water and an added electrolyte (no salt so I avoid creating Chlorine) so I can create an oxygen gas and route the gas to my hydroponics tank thus increasing the levels of oxygen in the water. The question is what acid or base could I use for the electrolyte that won't create harmful byproducts? Do you think I should pursue the electrolysis plan or go with my original idea?
FoolishSage
FoolishSage
Answer 8 years ago
You dont need electrolysis to increase the oxygen in the water. Either use a small air pump to bumble air in the water (you can use something like an aquarium disperser to get smaller bubbles) or let the water "crash" into itself (like a waterfall or when you fill a bucket from a tap). This kind of contact between water and air should provide ample oxygen in your water.
canucksgirl
canucksgirl
Answer 8 years ago
I would stick to the original idea (only because I'm not sure how you'd work the other idea).
canucksgirl
canucksgirl
Answer 8 years ago
Oh btw, check your Inbox.
Re-design
Re-design
8 years ago
I would not use sawdust. As you now most mediums are inert. Sawdust will decompose and suck the nitrogen out of the water depriving your plans of it. Sawdust may cause mold to grow.
steveastrouk
steveastrouk
Answer 8 years ago
Mold and fungi in hydro are killers for the plants. We always use a media-less NFT system, with lots of oxgenating surface. We start the plants in rockwool and then put them into the troughs.
thecoonskin
thecoonskin
Answer 8 years ago
Ah I see I'll be sure to steer clear of it then.
