77Views5Replies
Author Options:
Script to open up pptx or .xlsx files? Answered
My hard drive is no longer working. I took it to a company to recover data from this disk. But most of the files have no original names. And besides, they don't open, probably as a result of damage.
Is it possible to write a script to automatically try to open a file with the extension. pptx or .xlsx?
Is it possible to make it so that the whole good files has been moved for example in the folder
'C:\Success'. The files that are corrupt in folder 'C:\Failed'.
I'm not sure whether it is possible to do so? Maybe there is any guide how to restore them or utilities whether paid or free?
LukeOBirn
Best Answer 3 years ago
Ok I have
done 1 (XLSX) for you. I am sure you can replicate it for DOCX and PPTX ;)
Let me know
if you are still stuck. I have commented the code. Copy the code in a notepad
and rename the file with a vbs extention. Also before you run the file, change
the input and output folder.
Hope this
helps.
If this script will not restore .pptx files, I know one good tool PPTX Repair Kit for ms powerpoint pptx file repair. http://www.pptx.repair/
Code Sample
Dim FSO, FLD, FIL
Dim Ar, strInputFolder, strOutputFolder
Dim oXLApp, wbTest
'~~> This is the folder which has the 6000 File
strInputFolder = "E:\Sample\"
'~~> Output Folder
strOutputFolder = "E:\Sample\Success\"
Set FSO = CreateObject("Scripting.FileSystemObject")
Set FLD = FSO.GetFolder(strInputFolder)
'~~> Loop through all files in a folder
For Each FIL In FLD.Files
'~~> Get the File Extention
Ar = Split(FIL.Name,
".", -1, 0)
'~~> Check the extension
Select Case
UCase(Trim(Ar(UBound(Ar))))
Case "DOCX"
'~~> Replicate Code
using Code for "XLSX"
Case "PPTX"
'~~> Replicate Code
Case "XLSX"
'~~> Establish an
EXCEL application object
On Error Resume Next
Set oXLApp = GetObject(,
"Excel.Application")
'~~> If not found then
create new instance
If Err.Number <> 0 Then
Set oXLApp =
CreateObject("Excel.Application")
End If
Err.Clear
On Error GoTo 0
'~~> Hide Excel
oXLApp.Visible = False
'~~> Open files
Set wbTest =
oXLApp.Workbooks.Open(strInputFolder & FIL.Name)
On Error GoTo 0
If Not wbTest Is Nothing
Then
wbTest.Close (False)
Set wbTest = Nothing
'~~> Copy the file
FSO.GetFile(strInputFolder & FIL.Name).Copy _
strOutputFolder &
FSO.GetFileName(strInputFolder & FIL.Name), True
End If
End Select
Next
'~~> Clean Up
oXLApp.Quit
Set oXLApp = Nothing
MsgBox "Done"
gustanotests23
3 years ago
Try to open such file via Recuva or some online services which are very popular now.
Esa-PekkaMakela
3 years ago
I gave them the drive that they have extracted data from it. they did, but apparently they extracted them already damaged.
Downunder35m
3 years ago
If you had the data recovered but it is useless then you either choose the wrong company or got ripped off.
Besides: If you can't open them with the correct program, what difference would a script have? Damaged and useless is the same for the script as for the original program.
Smart people create backups of important files ;)
