210Views2Replies
Setting Default Program Mac OS X Help?
Under the Get Info window, I select the program I would like to set a new default for (in this instance, a .wmv file). I can select any individual file, and have it open in Quicktime, but when I hit the change all button, it changes them all to open in Streamclip (which I've never selected). I restarted, and the same thing continues to happen. I'm using Leopard (10.5). Help or ideas are appreciated.
Best Answer 9 years ago
I have 10.6.8, and (thankfully) don't have this issue, but from what I've found out, there are some quirks (if not a full fledged bug) associated with some versions...
That being said, there is a free app that will allow you to gain control over how your files open, and select whichever program you choose.
Here's the link: http://www.rubicode.com/Software/RCDefaultApp/
10 years ago
I haven't seen this problem myself, but I do have a somewhat related problem with setting the application via Get Info. I do that with shell scripts (setting the App to X11) so that I can launch them from my dock. The problem is that if I go back and edit the script, it loses the application setting :-(
