2231Views4Replies
Author Options:
So I'm trying to find the focal point of a satellite dish. Answered
The dish is oval, and I am not sure if it is parabolic/spherical. Here is a picture, with measurements: http://s753.photobucket.com/albums/xx180/EternityTransfer/
I'm not too sure how this dish focuses, as it seems that vertical waves will be focussed differently to horizontal ones, due to the oval shape and that the depths are different depending on which axis is measured.
I ideally want to make a parabolic microphone from this dish. There seems to be a focal point about 60cm from directly above the center of the dish, but when viewed from very off-centre angles, the dish seem to have other points too. How would I determine the "optimal" one?
It is coated in a thin layer of aluminium foil, which I put on to reflect light when finding the focal point.
Unfortunately there are no serial/part numbers, and the dish is missing its feed horn and support so I can't approximate the focal point form there or from datasheet(s).
Any help would be greatly appreciated.
EDIT: Oh and the dish originates in South Africa, and is stamped with a number which looks like a date of manufacture: 19950610. Googling the number yielded no results so its probably a date.
ARJOON
ARJOON
9 years ago
just place it in the sun and use an electric thermometer.
move the thermometer where u think that the focal point is. the highest reading is the focal point. This might take up to 5 mins max.
OR use a stick where it lights the most then you get it(not very accurate
Kiteman
Kiteman
9 years ago
The optimal focal point is wherever the signal receiver was when it was still working.
LinkVanyali
LinkVanyali
Answer 9 years ago
Ah, if only I still had the signal reciever. Sadly it was lost, and I have no way of figuring out how long it was.
NachoMahma
NachoMahma
9 years ago
.  It looks like a satellite dish for a DirecTV system. The FP is not centered on the dish as with older systems. You should be able to track down the dimensions/FP using the links.
