1197Views5Replies
Author Options:
Solar Cells Coating? Answered
Hi Guys!
A few weeks ago I found an auction on ebay, bid, and won myself some big old pack of solar cells. Now these panels are wafer thin, no coating or covering. Additionally, I need to put the wire collecting ribbons on myself. The only problem with these is that they are incredibly fragile. What can I coat them with to protect them? Is there any spray or acrylic or resin that you use to protect them?
Thanks
frollard
frollard
Best Answer 8 years ago
If you bought tabbed or tabless solar cells, they need to be laid out, tabbed, soldered, and glued to a strong enough substrate. Many diy people use a weather-sealed piece of plywood. To protect the front side of the cells once they are soldered, you need to get a transparent epoxy coating to paint over the whole panel. There are formulas designed specifically for solar panels to be as transparent as possible.
Barring that, once soldered and glued down -- by putting some sticky foam weather stripping around all 4 edges, you can then just lay a piece of glass over top of the panel and have it sealed shut that way.
frollard
frollard
Answer 8 years ago
http://www.solarpaneltalk.com/showthread.php?1118-Epoxy-for-encapsulating-cells-%28great-DIY-thread-with-photos!%29
see also: this guy is selling a pva sheet. http://www.youtube.com/watch?v=KVor7fKIcSs
Kiteman
Kiteman
8 years ago
To protect the ribbons once you've soldered them?
Blobs of hot glue or two-part epoxy would be fine.
transistorguy
transistorguy
Answer 8 years ago
No. The panels themselves. They are very brittle and fragile.
Kiteman
Kiteman
Answer 8 years ago
Ah, see Frollard's reply then.
