87Views1Replies
Author Options:
Solar Panel System Circuit Check, am I right? Answered
Okay so I'm about to start putting together a small Solar Charging Station to charge most of my small battery devices and I want to include a usb port to charge ipods and such. My system before integrating the usb will use a panel providing 12V to a 12V battery through a charge controller. The battery would then power devices through an inverter. I was planning on hooking up a 5v voltage regulator and 220uf capacitor in parallel to the battery and charge controller. My main concern is: Will any problems occur when hooking up a 5v device with a smaller battery in parallel to the other 12v battery through a voltage regulator? If so, how could i change the circuit to be safe and still allow for the usb port? Also would the use of a switching diode be of importance here? Thanks for the help!
Sandisk1duo
Sandisk1duo
12 years ago
If you get a 5v 500ma voltage regulator, you'll be fine!
