102Views3Replies
Author Options:
Solar panel: Shattered glass - epoxy or replace the glass? Answered
Hello,
I see many projects/videos about making solar panels or repairing shattered glass on solar panel with things like epoxy. But I have found nothing about chaging the glass of the solar panel.
The cost of epoxy  for a repair seems quite high (30$+?) and maybe not always suited long term. Assuming the cost of the glass wasnt much higher, is there something practical stoping a repair by chaging the glass rather than using epoxy?
Thank you!
rickharris
rickharris
Best Answer 4 years ago
Unless the solar array is bonded to the glass I don't see any reason not to change it . After all some one assembled the panel in the first place.
RincewindT
RincewindT
Answer 4 years ago
Thanks, good point about the bonded glass as I think that is the case (bits of glass in the corners do not seem to fall easily).
Josehf Murchison
Josehf Murchison
4 years ago
What kind of solar panel?
As Rick said, as long as nothing is bonded to the glass, or the glass is a special glass, it should be as easy as going to your local hardware and getting a new piece of glass. No different than fixing a broken window.
