16833Views8Replies
Soldering iron smoking?
Hi Guys,
I just bought a new soldering iron for the first time. When i plugged it into the wall outlet it started smoking (not alot) well that scared the living crap out of me, so I turned it off. So can any of you guys tell me that should I just dump the iron or is it normal. Please guys help (and there was a bit of smoke near the handle too). Oh and another interesting thing is that after 10 seconds of plugging it in it started melting solder ( its a 35 or 30 watt iron )
Thanks in advance.
-Prickly Potato
Best Answer 6 years ago
Depends on, where it is smoking. On any part that is expected to get hot (the tip [of course], the heating element) that is pretty normal, it's just burning off any coating and residues that is in those places - that is pretty normal and should stop in a few minutes. If anything that should stay cool is smoking (handle, cables, the controller station itself, if it has one), well that's a case for warranty.
10 seconds to start melting solder is okay.
Plug it in, let it sit for 10 minutes under close observation (and over a non-burnable surface) and try to tin the tip.
If you still can touch the handle and the only hot part is the tip and around - congratulations, take good care of your new soldering iron.
If you can't touch the handle, the controller gets more than lukewarm or anything still smokes (or burns...) send it back.
7 months ago
Soldering and cooking: don't do it if you don't have the time to continuously supervise.
Simple soldering irons work by induction. A coil surrounds the soldering tip base causing it to heat thanks to back and forth electromagnetism from alternating current. The coil and wires leading to it are usually protected with heat-resistant materials.These materials, however, will smoke a little (or a lot) on first use. Verence's recommendations should apply. Worry if you see flames, sparkles or parts that should not heat up get too warm (or melt). It's always best to connect them to a surge protector with a kill switch that you can reach fast if needed.
6 years ago
Even more important, is to turn-off that iron whenever you leave the room.
I know some one who rigged the iron power outlet to the room lights for insurance purposes.
6 years ago
A new soldring iron can produce some smoke due to the oil film on it that is protecting the metal.
Totally normal thing but it should not give smoke like a fire, after about 10 minutes the smoking should stop.
After that you only get smoke while using flux cored solder.
6 years ago
That is normal (if it is on the tip or shaft). Just a bit of flux residue or oil and grease (maybe from you're fingers) is burning off.
6 years ago
Yep, leave it plugged in, but watch it closely.
Answer 6 years ago
whoops i deleted my response and you had replyed
6 years ago
i recently got one too and it did the same thing i think it is because it is burning off the impurities just leave it on for a few minutes and it will stop smoking
