77Views5Replies
Author Options:
Someone can help to build a small system to mix three gas from three various tanks and compressing it in a fourth tank? Answered
I need a small system to mix three gas (carbon dioxide, helium and hydrogen) from three various tanks and compressing it in a fourth tank. I don't need high pressure, but I need extreme accuracy and purity in the ratio of the mix. I want to try different ratio in gas mixture, then I need to regulate any single gas amount
steveastrouk
steveastrouk
Best Answer 9 years ago
The only real accurate way to do this would be to use Mass flow controllers, from someone like Tylan (or whatever they are called this month - long story)
They ain't cheap, but you can pick them up on Ebay for ~200 USD if you're lucky. They are calibrated SPECIFICALLY for the gas you push through them.
Steve
en2oh
en2oh
6 years ago
Hi there,
Not sure if this is even still relevant to you, but the Mass Flow Controllers on ebay are as low as $30 each. WHile they are calibrated to a specific gas, they can be recalibrated to any gas.
Have you gotten anywhere with this project?
lemonie
lemonie
9 years ago
What for?
Why not use the blended gas stream direct from the three cylinders?
L
GiorgioSteimetz
GiorgioSteimetz
Answer 9 years ago
I try to built a little laser and I need only one little tank
lemonie
lemonie
Answer 9 years ago
That doesn't answer my question; i.e. why blend it and put it in a tank, then take it out of the tank and use it, when you could omit put it in a tank, then take it out of the tank?
L
GiorgioSteimetz
GiorgioSteimetz
Answer 9 years ago
My design would be for a gas flow laser , so I need to blend the gas and put it in a little tank, than connect this tank to the laser.
I don't have experience, it's my first project...
lemonie
lemonie
Answer 9 years ago
Why not just blend the gas as you need it? if it flows, mix three flows - you need good regulation though (steve).
L
