309Views6Replies
Author Options:
Spark gap ions? Help Please? Answered
Hi!
I was wondering what kind of ions are emitted from a spark gap when in use? I have seen alot about negative ions and positive ions, but could someone shed some light on this?
Also, how harmful are these ions to the body and what exactly are they made of?
THANK YOU
ANY sources that help explain this will also be appreciated!
Again, THANK YOU
Burf
Burf
Best Answer 10 years ago
An ion is either a negatively or positively charged molecule or atom.
A spark gap or electrical arc can only affect those molecules or atoms within its proximity. An electrical spark through a vacuum will not create any ionization except possibly the materials composing the anode and cathode. In air, the usual ions are nitrogen and oxygen ions, in an internal combustion engine, the ions might also include carbon and carbon compounds.
So, the answer to your question is, it depends. It depends on where and what materials are present when the electrical arc occurs. A lightning bolt on earth will create a different set of ions than does a lightning bolt on Jupiter.
Just Google for "What is an ion?" and you'll get more information than you can use.
orksecurity
orksecurity
10 years ago
Mostly you're going to be ionizing the air between the contacts. Exactly which gasses depends on the voltage, but oxygen is typical (hence the smell of ozone from high-voltage electrical equipment).
transistorguy
transistorguy
Answer 10 years ago
Do you think it would be possible to direct this stream of ions between the contacts at a target?
lemonie
lemonie
Answer 10 years ago
One of your contacts would need to be the target for that.
L
steveastrouk
steveastrouk
10 years ago
Two atoms sitting in a bar, one turns to the other and says "I've lost an electron" and the other says "are you sure ? " and the first atom says "yes, I'm positive"
Steve
