599Views13Replies
Author Options:
Splitting CO2? Answered
Is there a way to electronically split CO2
I want a strait answer no junk about it being to hard
iceng
iceng
Best Answer 9 years ago
You are correct CO2 ain't hard at all. It's a gas. This is in the easy realm of particle physics. Use a simple cyclotron (patented in 1934 by Lawrence) just two metal D plates and an alternating voltage will accelerate a particle up to enough speed to split the molecule of your choice.
Are you collecting carbon?
jj.inc
jj.inc
Answer 9 years ago
Yea, I meant that CO2 was to hard (requires to much energy) to separate practically.
I actually just wan't to find out if there is a way to easily split CO2 electronically for say a space shuttle or space station, do they do this. I would then try to find a way to turn the carbon into something useful.
Msunthankar
Msunthankar
7 years ago
Could I split CO2 with hydrogen relatively easily ? Under what conditions ?
jj.inc
jj.inc
Answer 9 years ago
Yes, I have searched it, I always find the answers like photosynthesis, extreme heat (but you have to separate at high temp or they will recombine), or that it requires to much energy to be any benefit.
kelseymh
kelseymh
Answer 9 years ago
And what do you conclude from that?
jj.inc
jj.inc
Answer 9 years ago
That not very many people have the knowledge of this. I know you can input energy without having to separate the two while the energy is applied I just didn't know how to do it. I have seen machines that do it, but nobody says how and now I have my answer so I conclude. If you at first you don't succeed try on your own again.
steveastrouk
steveastrouk
9 years ago
OK, take two platinum electrodes, and preheat a bath of calcium carbonate to ~550 C. Bubble the gas into the carbonate.
Failing that, solid, gadolinium doped cerium oxide works too.
Steve
jj.inc
jj.inc
Answer 9 years ago
What will happen, will it output separate carbon and oxygen gas or will one be left inside the calcium carbonate? They won't recombine will they?
Also what does "Failing that, solid, gadolinium doped cerium oxide works too. " mean.
steveastrouk
steveastrouk
Answer 9 years ago
There is no such thing as carbon gas, until you reach many thousand Kelvins. basically, not all the CO2 is split.
jj.inc
jj.inc
Answer 9 years ago
I meant carbon, and gaseous oxygen, but this method doesn't really work that well
jj.inc
jj.inc
Answer 9 years ago
Sorry I think I needed straight but I was in a hurry this morning. ☺
