806Views5Replies
Author Options:
Strong Egg Timer mechanism? Answered
I want to a mechanism that turns a drum very slowly for a few hours.  It should work just like an egg timer: You wind it up and then it turns slowly. Is there mechanism available that works like this or do I have to built it from scratch?
steveastrouk
steveastrouk
7 years ago
You'll need to put some quantities on "a few hours" - how many ?
"A drum" - what size ?
"Slowly" - how slow ?
A weighted clock type drive would be simple enough.
uwe999
uwe999
Answer 7 years ago
good questions, thanks.
The drum should turn about 1x per minute or less and should run for up to 8 hours.
The drum is 2 ft in diameter and needs about 5 ftlbs max to turn.
Where can I get a "weighted clock type drive"?
cheers
steveastrouk
steveastrouk
Answer 7 years ago
I may be wrong, but I reckon you're going to have to do it from scratch, if its the way you want to go. Its basically a pendulum clock.
rickharris
rickharris
Answer 7 years ago
There are many speed controlling mechanisms in the clock work world.
From swinging balls to fans.
Smart grease is also a good option depending on how slow you want it to go and how variable it needs to be.
http://www.rapidonline.com/Education/Smart-Grease-Starter-Pack-06-1294/?sid=9ea25341-8288-46cb-90ca-c9b1d2112ed0
steveastrouk
steveastrouk
Answer 7 years ago
I'm thinking that "fans" and "grease" are energy lossy though, but an escapement isn't
