81Views3Replies
Author Options:
Suitable transistor or IC to run 1 Watt LED in low voltage? Answered
I want to run 4 x 1Watt LEDs from a 3.7V source (10000mAh).
LED DC Forward Current: 350mA
The purpose is to sue it with a motion sensor.
Please suggest a transistor or IC with maximum efficiency.
Update: I found that the "IRF 540" Mosfet is a good solution.
Tags:LDR
-max-
-max-
Best Answer 4 years ago
"Please suggest a transistor or IC with maximum efficiency."
Did you know that your computer is capable of helping you do research? Let me teach you!
http://lmgtfy.com/?t=s&q=5W+3.7V+LED+driver
If you actually want an IC, check digikey or mouser and use the parametric search to narrow down to what you want. You may need to open the datasheets for all the chips to see the efficency curves.
steveastrouk
steveastrouk
4 years ago
Look on Ebay for a boost LED driver, with a 9v output at 350mA
shijilt
shijilt
Answer 4 years ago
The power source will be 4 rechargeable batteries - 10000mAh.
steveastrouk
steveastrouk
Answer 4 years ago
Hmm.
