264Views3Replies
Symbols in Word 2003 and up?
Used to have word '2000'. It was easy to allocate symbols, like 'degree', (small circle in uppercase). I used to allocate <alt>D for this symbol. Now I have a newer version (2003, really HATED the Word 'Vista' version...)! But it seems hard to allocate any shortcuts for symbols now... People, please tell me how to do it..., otherwise I will delete it (again...). The 2003 Office Suite, to be replaced by the decade old ' Office' version???
Please don't tell me the buggy old 'open office' is better... Just put it on your USB stick...
Best Answer 10 years ago
If you go to "Insert" and then select "Symbol" in the dropdown, you get the symbol-selector.
The selected symbol is highlighted and right above the "insert" button you'll find the currently active key-combination. An upside down exclamation mark would be ALT+CTRL+!
You can also change the key-shortcut in this menu.
10 years ago
Hey BobS,
Adding a shortcut to Word 2003 is pretty straight forward. Simply select insert-symbol... select the symbol you want (say the degree sign) and click the shortcut button... then press your shortcut (Alt-D)... and click assign... you can also assign an auto-correct (by pressing the auto-correct button instead of shortcut) so every time you type a certain string of characters and press space it will turn into the symbol you want.
There are a lot of guides for this sort of stuff on the web... so next time I'm sure you would be better off by googling your question first.
Answer 10 years ago
So nothing changed! I used to do this all the time, and had built up a range of often used symbols, like degree, Euro and some Greek symbols.
This was the first time I needed the degree symbol since installing W7 and office 2003 on my replacement HDD after a crash this summer.... I just forgot how to do it!!!
