1263Views1Replies
Author Options:
TRANSFORMER capacitor taser spark gap help? Answered
hey guys ive made quite a few things with capacitors and modded things with transformers but im pretty new to transformers and wanted to know if anybody could either post a simple tutorial on how to us transformers or inform me on how to make a spark gap. also is it possible to up the voltage in the transformer to make the capacitor rapid charge. i have a potao canon with a crappy ignition sytem and was going to make one but i need help with the transformers
Re-design
Re-design
10 years ago
Transformer tutorial.
Small number of windings on the primary side and large number of windings on the secondary side.  Maybe 50 and 10,000 will generate a large voltage but with small amps.
A small spark plug makes a good spark gap for lighting vapors.
If you can get a small ignition coil from a modern car motor then you can use that.
Using a battery and a pushbutton switch the make and break of the switch causes the high voltage as the field builds and collapses.
