88Views9Replies
Author Options:
Tablet battery power - affected by HDMI-VGA monitor connection? Answered
I have a 7" Windows 8.1 tablet running a music (MIDI/VST) program to provide sounds via the audio output. Input is via an OTG microUSB cable connected to a USB MIDI 'mini' keyboard (Akai LPK25 - USB powered). The audio is connected to Line In of a Yamaha Tyros keyboard and it works. I intend connecting a VGA monitor to the micro HDMI tablet port (microUSB to VGA adapter and VGA cable) and would like to know if there will be increased draw on the battery.
Is there a way to supplement the power to the tablet as the charger uses the same microUSB port?
gibwig
2 years ago
Solution for the USB power. Just found a <$15 OTG adapter from Amazon US or UK which has 3 USB ports and microUSB port for simultaneous charging by AC supply (or battery booster pack).
rickharris
Best Answer 2 years ago
Sorry I miss read - using the HDMI shouldn't make a big difference to the battery - try it.
gibwigQuadrifoglio
Answer 2 years ago
Thanks for the suggestion, it's an interesting device but quite expensive. Also I see that it is "Not a standard USB OTG dock. Will not work for all Windows tablets."
gibwigQuadrifoglio
Answer 2 years ago
Thanks for the great link! Seems I don't have an HDMI power issue as the tablet display can be turned off and the USB drain is minimal.
Downunder35m
2 years ago
No offence but a lot of monitors offer a HDMI input, and any cheap flatscreen TV as well - why go through all these troubles?
The adapter will cost you more than a second hand TV ;)
gibwigDownunder35m
Answer 2 years ago
Thanks, but the adapter was US$6.50 (£5 from Amazon UK) and it's a 15" flat screen spare monitor I already have. It's the power draw if any from the tablet that concerns me.
gibwiggibwig
Answer 2 years ago
However, I now realise you can set the display to external monitor only which turns the tablet display off (and uses less battery) anyway.
rickharris
2 years ago
Almost certaily - Use a powered hub
gibwigrickharris
Answer 2 years ago
Thanks, that will help the USB side, but the monitor connects through the tablet's microHDMI port.
