98Views5Replies
Tall irrigated hedge to pre-cool A/C condenser?
I am thinking about planting a hedge around our air conditioner condenser to increase its efficiency. This would serve as shade for the condenser and as a means to inject water to keep the plant cooling the air as it evaporates the water. When rainwater is available, an aquarium pump could "irrigate" the hedge. When not available, a switch could control a valve for a high-pressure drip irrigation system. Both could be controlled by the compressor circuit. Keep the hedge trimmed about 6 feet tall and with just enough space around the condenser for a workman to easily maintain the unit (at least 3 feet from the condenser). The hedge would have to be drought resistant and one that does not shed leaves or debris. Any thoughts about this?
Best Answer 4 years ago
Transpiration (plant evaporation/cooling) to the point where we would notice it works on a large scale, like with big trees. However, its effect is easily eliminated by a breeze. A hedge won’t have enough scale, and what effect it does have will quickly be eliminated by the volume of air moved by the ac unit. A dense enclosure might actually create a heat well with recirculating hot air.
The other contributor of a large tree is shade. Considering a hedge for shade, in Chicago, at the summer solstice, a 6-foot hedge to the south of the unit will only provide 2-feet of shade. It won’t even shade all of the access space, much less the ac unit. With six foot hedges to the east and west, the ac unit will be fully exposed for about five hours. An ac unit, tucked up against the east side of the house, with eaves, is the best location. It is in the shade for the hottest part of the day.
Humidity, in and of itself, has little effect on the condenser efficiency. Misting can help but introduces a whole bunch of new problems like scale, corrosion, and operating an electric device in a wet environment.
So, what can you look at to improve efficiencies?
4 years ago
To give useful suggestions, we really need to know where in the world you are, soil conditions etc,
Your best sources of information are your local garden centre, or have a stroll around your local area to see what your neighbours are growing successfully - if you see something you like, knock on the door and ask what the species is. If they don't know, ask nicely for a twig to use for ID purposes.
Answer 4 years ago
Thank you for your tip. I am in Naperville, IL near Chicago and have very good soil.
Answer 4 years ago
And a river stained green by nearby copper or deposits... Used to enjoy the municipal quarry swimming pool very much... I concur that you want to keep bushes away from your unit. Shading the unit and providing non recirculating air flow is escential..
Answer 4 years ago
Iceng: I do not understand your post. Please edit it so it is coherent and on-topic.
Answer 4 years ago
It was youwho brought up Naperville, IL near Chicago, which was a nice place with friendly people when I spent time there in the seventies and good soil involves geology with rivers and bodies of water.
I fully agree Quadrifoglio's comments on your primary topic. Besides the 5 languages you speak I was speaking Electrical Mechanics sorry to confuse you Virgil.
The main thrust of my comment was that it is unwise to arrange a structure (hedge) that may under appropriate conditions like_a_calm_day allow cooling airflow to recirculate through the condensing coils.. This is because airflow is necessary to remove heat from inside the machine... It stands to reason that recirculating the same air will be bringing heat back to your AC unit and that is not the ideal intended operating situation, as higher heat on electrical devices is deleterious to service life.
Just to make sure to tell you an old EE's opinion which is what I am.
I do not believe you really have anything to worry about. Just put your AC on a raised concrete pad above the 50 year flood level for your neighborhood.
4 years ago
As far as I know, all higher plants shed something.
You might try for something that does it all at once - like in the fall. Lilac is easy to grow and trim. It likes being mowed to within 12" of the ground from time to time. The flower heads are easy to cut off... in bud, in flower, or as seed heads, so you needn't have flower bits getting into things. The leaves are big enough to be easy to rake, and if I remember correctly, tend to fall all at once.
I suggest avoiding anything with needles or tiny leaves that could fall into the condenser Plants have needles to reduce water loss through transpiration. I think in general, plants that are drought resistant also try to reduce water loss that way.
