115Views5Replies
Text onto soda can
I'm trying to apply some text onto the material from a soda can, but I don't have the neatest handwriting and it's not even meant to be a normal font. What are some good ways to apply some guidance for me when I go to actually scribe onto the material?
The end result I'm aiming for is a box similar to this one;
https://www.instructables.com/id/Drink-Can-Tinwork/
but with the Sith Creed written in one of the Star Wars fonts, and most of the visible work being done by a dremel.
I've thought about making a stencil, but I'm not sure I can reasonably cut some of those shapes at the necessary size.
Toner transfer may be an option, but I am not too familiar with that process.
5 years ago
Actually, search it on make: and you'll find an article by Sean Michael Regan on using one of the old hand embossers with soda can aluminum..
5 years ago
You get blue stencil foil that is activated by UV light.
So you printwhat you like on the foil, develop it in the sun for a few minutes and you are left with a thin pieve of plastic containing your writing.
But if you want to use a dremel anyway I would just print on normal paer, use a glue that dissolves in water and grind through the paper.
5 years ago
Carbon paper might work. Print your design on an inkjet, transfer to can with the carbon paper. Go over that with a Sharpie if it's faint. Emboss.
Reply 5 years ago
do you mean print directly on the carbon paper, or print on another sheet and attatch them to scribe together?
Reply 5 years ago
Try printing to regular paper, then taping a sheet of carbon paper to the back of that. Trace the design my hand; it should transfer.
