367Views7Replies
The correct Diode Specifications for Solar Panels in parallel.
Hello Guys I have a question,
If you connected 4 of 250Watts 24volts solar panel in parallel before connecting them to your charge controller, what would be the recommended blocking diode rating on each of these panels?
4 years ago
Why would not a single hockey puck diode work with all four identical panels wired directly in parallel just the discharge stop ?
Or are you mounting them in different sun positions or building shadows ?
Answer 4 years ago
My reason for asking is that I am concerned about the peak inverse rating on the diode.and Current rating. After the 4 solar panels are in a parallel connection it will be 24volts and the current 40amp approx. So I think I need diodes that have that or slightly higher peak inverse rating. Am I making sense?
Answer 4 years ago
The diode only needs to block 24V lets use a 50V inverse diode for when the solar array becomes a resistor at night or cloudy day..
The 50v PRV ( Peak Reverse Voltage ) is a one way current valve that prevents your 24V Battery from pushing any current back to the solar array at night.
I'm holding a 100V PRV 700 Amp diode that wont even get warm at 160 Amps. So you could wire all 4 panels in parallel and use a single diode.
The only strange feature of Puck diodes is that you must apply about 200LBs or more of parallel force to make the diode connect...
4 years ago
You are looking for a 250 W 15 +A diode like 1N5812 or MBR1635
Answer 4 years ago
Thank you Josehf. I expect that after connecting the diodes to the panels and then connecting all 4 panel cables in parallel the amp after the diodes will be 4 times more. which would be approx 40amps, 24volts. So in this case I believe that you definitely confirm that the 1N5812 or MBR1635 would be perfect for this setup.
Answer 4 years ago
They should be quite good, these diodes will connect to a heat sink for better heat dissipation.
If you do not have those diodes go here and use their search engine to find something.
http://ca.mouser.com/Electronic-Components/
I got 100 transistors from Mouser for the same price a 5 at Radio Shack. They are good for datasheets also.
4 years ago
A 10 Amp at least. since 250/24 is roughly 10.
